Yesterday I bought a linksys hub, 10/100 nic cards and cables and networked my two P3 systems together. One system is running win 2k and the other ME, my dsl speeds were about 450 down and 230 up and when it goes thru the hub my down speeds stays but my upstream went to 24! Any ideas on what I might need to do. Here's my setup: the gateway that controls my dsl goes into my hub in the uplink port and then the other rj45 cables goto my 2 computers out of the hub in slots 2 and 3. Any ideas? Thanks
Installed a hub and now my dsl upstream went WAY down, can someone help..
The hub may have this effect since it forces your computers to share the total bandwidth of the system (as I understand it). Also, a hub requires your ISP to assign one IP address for each computer. You may be limited to one IP address by your DSL ISP. They may give you trouble if you consume more than one address.
The optimum (cheap) hardware to connect your pcs is a DSL router, such as the Linksys BEFSR41:
http://www.linksys.com/products/prod...prid=20&grid=5
Personally, I recommend the Zyxel Prestige 314:
http://www.zyxel.com/html/product/wan/p314.html
Both are available at Buy.com. They provide a firewall and connectivity between your computers in the form of a DHCP server and 4-position switch which is faster than a hub (active instead of passive). Also, they use only one ISP address.
I'm relatively inexperienced with this stuff, so others may have more informed opinions.
The reason I recommend the Zyxel router is that it gives me little or no problems. I returned a Linksys BEFSR41 router because it was dropping my connection through PPPoE. At that time this was a weak point with this router (as stated by their tech support). I don't know if they've fixed this or not. As I understand it, it was only a problem with the PPPoE configuration. Not everyone had a problem.
[This message has been edited by Brian R. (edited 01 October 2000).]
Brian- The dsl I signed up for says it supplies 2 ip addresses and I set both to auto detect ip and they are different. I can't imagine I would need to buy yet another piece of hardware to make this thing work but maybe so. Thanks for the response.Asus P2b(1011),P3 500,256 mb pc133,Matrox G400 DH,Asus 50x,Iomega zip,Mitsumi CDR,Ibm 20 gb hd,Promise ultra 66 controller,Sb Live,Win 2000 pro
Are you sure that all the wires you are using are good? I've seen transfer rates shot to hell by wires that are too long and/or low quality. What's packet loss like?
Wombat- thats a possibility, i'll check my cables. Two really long ones came with the kit I bought and I already have 3 other short ones so i'll switch them around. How do I check packet loss?I'm using win 2k on my main system. ThanksAsus P2b(1011),P3 500,256 mb pc133,Matrox G400 DH,Asus 50x,Iomega zip,Mitsumi CDR,Ibm 20 gb hd,Promise ultra 66 controller,Sb Live,Win 2000 pro
Kookstick as long as the wiers are under 50m you should be fine!
EDIT: Oh you are from USA 50m is ~150feet
Join the MURC SETI team! | SETI @ MURC
[This message has been edited by Guru (edited 01 October 2000).]According to the latest official figures, 43% of all statistics are totally worthless...
I don't know what you would use in Windows. And I've seen a 50ft cable cause huge problems when a 20ft cable fixed the worries.Gigabyte P35-DS3L with a Q6600, 2GB Kingston HyperX (after *3* bad pairs of Crucial Ballistix 1066), Galaxy 8800GT 512MB, SB X-Fi, some drives, and a Dell 2005fpw. Running WinXP.
Err... see... there's a twisted vs. non-twisted issue here. My cable modem requires a twisted wire to run from the modem to the PC. HOWEVER, when I run the modem into my switch, it HAS TO BE a non-twisted wire or it just won't work.
So you may be better off switching wire types and going into a standard port.
Or get a switching hub.
- Gurm
Listen up, you primitive screwheads! See this? This is my BOOMSTICK! Etc. etc.The Internet - where men are men, women are men, and teenage girls are FBI agents!
I'm the least you could do
I would still get screwed
Get a cheap $50 LinkSYS switch from Buy.com. You response time wil go back to normal. Worked for me.
Jammrock
Athlon 650, Biostar board, 128 MB PC133 (Crucial), G400 32 MB DH, SB Live! w/ Digital I/O, 10/100 NIC, lots of case fans, etc...“Inside every sane person there’s a madman struggling to get outâ€
you may wish to check to see if your dsl provider uses collision avoidance or collision detection...detection only will interfere with your upstream performance because it will stop and start the data flow whenever both systems are in use...the downstream will maintain because it is not bottlenecked by the modem. I think this may be one of the more annoying limitations of the PPOE protocol...
Ali- I believe it has to go in the uplink because it wont work otherwise, it has a gateway which I guess is some kind of modem.Asus P2b(1011),P3 500,256 mb pc133,Matrox G400 DH,Asus 50x,Iomega zip,Mitsumi CDR,Ibm 20 gb hd,Promise ultra 66 controller,Sb Live,Win 2000 pro
could someone explain the difference between hubs and switches because they seem to do the same thing, yet the switch is faster at doing it. Why use a hub then? Maybe I will return it all for a refund and get 2 better nic's and a switch instead.Asus P2b(1011),P3 500,256 mb pc133,Matrox G400 DH,Asus 50x,Iomega zip,Mitsumi CDR,Ibm 20 gb hd,Promise ultra 66 controller,Sb Live,Win 2000 pro
