Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 46
Thread: US Commercial Crew spacecraft: Boeing Starliner OFT decision
  1. #16
    Moderator Dr Mordrid's Avatar
    Apr 2001
    Westland, MI
    26,335
    Crew Dragon static fire video (slo-mo)
    https://twitter.com/commercial_crew/...73732034396160
  2. #17
    Apr 2001
    Westland, MI
    26,335
    1) Sounds like Crew Dragon DM2 carries a crew to ISS first. This includes extra crew training.
    Chris G - NSF @ChrisG_NSF
    NASA says they've done everything to allow #DM2 (SpaceX's crew test flight) to stay for a long duration mission on ISS. NASA is just waiting for time to pass as the vehicles work through final certifications for flight. #SpaceX #Dragon #NASA
    https://twitter.com/ChrisG_NSF/statu...80893470109697
    2) Boeing Starliner scheduled its OFT (orbital un-crewed) test flight for December 19 at 0659 Eastern. This delayed from December 17 because of a problem with the Atlas V N22* rocket
    * N22 = No fairing, 2 solid boosters, 2-engine Centaur upper stage
  3. #18
    Apr 2001
    Westland, MI
    26,335
    Crew Dragon schedule alert!!
    Stephen Clark @StephenClark1 (SpaceFlightNow)
    Hello from Hawthorne. Got to see the Dragon for the Demo-2 crewed mission. SpaceX aims to ship it out of factory by the end of year for thermal vacuum testing. Gwynne Shotwell says the target date for the in-flight abort test is Jan. 4. She says Demo-2 as soon as February.
    https://twitter.com/StephenClark1/st...28237364105217
  4. #19
    Super MURCer UtwigMU's Avatar
    Jul 2002
    Sin City
    5,250
    Von Braun -> John Glenn = 17 years
    Space shuttle -> now >= ~9 years
  5. #20
    Apr 2001
    Westland, MI
    26,335
    Some say it should have only been 7 years, but in doing that the nitrogen tetroxide/titanium incomparability discovered during the DM1 test fire may not have been discovered. NASA's already looking at it as a possible cause of some unexplained failures.
  6. #21
    Super MURCer MultimediaMan's Avatar
    Sep 1999
    Bentonville, Arkansas, USA
    1,901
    Titanium is a fairly reactive metal. When I worked for Pratt and Whitney, there were many solvents which couldn't be within 3 Feet/ 1M of titanium, Trichloroethane was one of them, Tri-Sodium Phosphate was another. Nitrogen Tetroxide's reactivity with Titanium has been known since the 1950's. What is new is that "printed" and Metal Injection Molded are somewhat unpredictable with how they interact in these acidic/basic environments (with their fairly amorphous structures) and with the binders which are used to make the base material more formable. Right now, a lot of research is going on to artificially age Printed and MIM parts and see how they change over time, structurally and chemically. Right now, MIM has some fairly strict part size limits, but as technology marches on, the parts will get ever-larger, and as they do these research projects will be crucial to determining the suitability of metal Printing/MIM processes for ultimate durability.
    Case in point: Phosphoric Acid (Naval Jelly) will reduce iron and steel parts made with the Metal Injection Molding process to crumbly bits in a few hours, where conventional cast and forged parts are virtually invulnerable to Phosphoric Acid after a few minutes (after the Phosphoric Oxide forms). The mechanisms that make the damage possible in MIM are a result of manufacturing process itself... the binders make the base metal more porous, and often have (many, many) layers of oxides which the acid can attack.
  7. #22
    Apr 2001
    Westland, MI
    26,335
    AIUI, the old paper noted NTO/Ti flammability, but they found it wasn't self-propagating at thruster line pressures. Apparently they didn't test at the pressures used in the SuperDraco pressurization system. When a slug of NTO leaked into that line and it was pressurized during SD startup, the slug slammed into the Ti valve and <boom>.
  8. #23
    Apr 2001
    Westland, MI
    26,335
    The SpaceX Crew Dragon In-Flight Abort test is now NET January 11, and...
    Jim Bridenstine ✔ @JimBridenstine
    Great news!
    https://twitter.com/spacex/status/1209201762596356096
    SpaceX ✔ @SpaceX
    Yesterday the team completed the 10th successful multi-chute test in a row of Crew Dragon’s upgraded Mark 3 parachute design – one step closer to safely launching and landing @NASA astronauts
    https://twitter.com/JimBridenstine/s...14023939624961
  9. #24
    Apr 2001
    Westland, MI
    26,335
    Assuming the In-Flight Abort test goes as planned in mid-January, the Crew Dragon & booster for DM-2 should arrive at KSC in February. After that it's reviews & certs before astronauts take their ride.
  10. #25
    Apr 2001
    Westland, MI
    26,335
    https://blogs.nasa.gov/commercialcre...date-update-3/
    SpaceX In-Flight Abort Test Launch Date Update
    NASA and SpaceX are targeting no earlier than Saturday, Jan. 18, for an In-Flight Abort Test of the Crew Dragon spacecraft from Launch Complex 39A at the Kennedy Space Center, Florida, pending U.S. Air Force Eastern Range approval. The new date allows additional time for spacecraft processing.
    The demonstration of Crew Dragons in-flight launch escape system is part of NASAs Commercial Crew Program and is one of the final major tests for the company before NASA astronauts will fly aboard the spacecraft.
  11. #26
    Apr 2001
    Westland, MI
    26,335
    @SpaceX
    Static fire of Falcon 9 complete – targeting January 18 for an in-flight demonstration of Crew Dragon’s launch escape system, which will verify the spacecraft’s ability to carry astronauts to safety in the unlikely event of an emergency during ascent
    https://twitter.com/SpaceX/status/1216022644614545409
  12. #27
    Apr 2001
    Westland, MI
    26,335
    Boeing's Starliner won't be doing this test - they're depending on a simulation.
    Date: January 18
    Time; 0800-1200 Eastern
    https://www.nasa.gov/feature/spacex-...-demonstration
    SpaceX, NASA Gear up for In-Flight Abort Demonstration
    NASA and SpaceX are preparing to launch the final, major test before astronauts fly aboard the Crew Dragon spacecraft and Falcon 9 rocket to the International Space Station as part of the agency’s Commercial Crew Program. The test, known as in-flight abort, will demonstrate the spacecraft’s escape capabilities - showing that the crew system can protect astronauts even in the unlikely event of an emergency during launch. The uncrewed flight test is targeted for 8 a.m. EST Saturday, Jan. 18, at the start of a four-hour test window, from Launch Complex 39A in Florida.
    SpaceX performed a full-duration static test Saturday, Jan. 11, of the Falcon 9 and completed a static fire of the Crew Dragon on Nov. 13, setting the stage for the critical flight test.
    Prior to launch, SpaceX and NASA teams will practice launch day end-to-end operations with NASA astronauts, including final spacecraft inspections and side hatch closeout. Additionally, SpaceX and NASA flight controllers along with support teams will be staged as they will for future Crew Dragon missions, helping the integrated launch team gain additional experience beyond existing simulations and training events.
    After liftoff, Falcon 9’s ascent will follow a trajectory that will mimic a Crew Dragon mission to the International Space Station matching the physical environments the rocket and spacecraft will encounter during a normal ascent.
    For this test, SpaceX will configure Crew Dragon to intentionally trigger a launch escape prior to 1 min, 30 seconds into flight to demonstrate Crew Dragon's capability to safely separate from the Falcon 9 rocket in the unlikely event of an in-flight emergency. Once the launch escape sequence begins, Falcon 9's first stage Merlin engines will shut down and Crew Dragon’s SuperDraco thrusters will begin their firing sequence. The launch vehicle and spacecraft will separate, and Crew Dragon's SuperDracos will burn to completion.
    After Crew Dragon's SuperDracos shutdown, the spacecraft will passively coast to apogee, the highest point in its arc. Near apogee, Crew Dragon's trunk will separate and the smaller Draco thrusters will re-orient the spacecraft for reentry and parachute deploy. At the appropriate conditions, Dragon’s drogue and main parachutes will sequence to provide for a soft landing in the Atlantic Ocean near SpaceX Dragon recovery teams.
    Following Crew Dragon’s separation, Falcon 9 is expected to aerodynamically break up offshore over the Atlantic Ocean. Expected breakup time will vary based upon a number of factors, including day of launch winds and expected minor variations in vehicle attitudes and positions, but could occur shortly after separation or later upon reentry from the upper atmosphere. In either scenario, a dedicated team of SpaceX Falcon 9 recovery personnel will be staged and ready to begin recovering debris immediately after breakup.
    As part of the Dragon recovery operation, Air Force Detachment-3 personnel will work with the SpaceX recovery team to observe Crew Dragon and practice their initial approach to the spacecraft in the open ocean, mimicking an actual rescue operation before the SpaceX team recovers Crew Dragon for return to Cape Canaveral.
    SpaceX's uncrewed in-flight abort demonstration test of Crew Dragon's launch escape capabilities is designed to provide valuable data toward NASA certifying SpaceX's crew transportation system for carrying astronauts to and from the International Space Station.
  13. #28
    Apr 2001
    Westland, MI
    26,335
    Heads up;
    IF the Crew Dragon In-Flight Abort from LC-39A doesn't launch on Saturday it's possible it could launch on Monday morning, a few hours before the StarLink 3 mission from LC-40. Unlikely, but possible.
    Yeah, two in one day from the same range
  14. #29
    Apr 2001
    Westland, MI
    26,335
    Crew Dragon In-Flight Abort rollout
    @spaceflightnow
    SpaceX’s Falcon 9 rocket and Crew Dragon capsule have arrived at pad 39A in Florida, where the vehicle will be lifted vertical in preparation for an in-flight test of the human-rated ship’s launch escape system Saturday. https://t.co/e9tMYft6Jd https://t.co/5y6fLudCmp
    https://twitter.com/spaceflightnow/s...49441606164481
  15. #30
    Super MURCer KRSESQ's Avatar
    Feb 2000
    Bismarck, ND USA
    3,268
    Quote Originally Posted by Dr Mordrid View Post
    That's just straight up loony.
    Here is an interesting article about how Boeing bought out McDonnell Douglas and McDonald Douglas essentially took over Boeing (and not for the better).
