Page 10 of 11 FirstFirst ... 8 9 10 11 LastLast
Results 136 to 150 of 156
Thread: SpaceX Starship & Super Heavy [Floating Spaceports]
  1. #136
    Moderator Dr Mordrid's Avatar
    Apr 2001
    Westland, MI
    26,163
    Boca Chica's definitely evolving into a space-shipyard, and Starship test vehicle SN3 is stacking.
  2. #137
    Apr 2001
    Westland, MI
    26,163
    Starshio SN-03's propulsion module being moved to the pad for pressure tests, static fires, and test hops & flights.
    https://youtu.be/rTzETiB4ZIU
    https://youtu.be/tD2OTUQ54LU
    On the test stand
    https://twitter.com/austinbarnard45/...75798922035200
  3. #138
    Apr 2001
    Westland, MI
    26,163
    Starship SN-03 is on the pad at Boca Chica TX preparing fof pressure tests, static fires and hops. 3 large hydraulic jack's have been installed to simulate Raptor thrust loads during the pressure tests.
    SN-04 parts are in production, and new infrastructure is being built.
    Latest news:
    Starship SN-03 has a new landing leg design. There are 6, and before deployment they're folded up into the engine bay. When deployed these legs flip out and telescope, giving Starship a wider stance when landed.
    Up-skirt view of SN-03 showing the yellow thrust-load jacks, which simulates the thrust of the 3 center Raptor sea level engines, block the view of 2 legs.
    - Starship SN-04 on will have even longer telescoping legs for an even wider stance.
    - 3 more Raptor vacuum engines and 3 lower cargo bins, or 6 more Raptor sea level engines, can also fit in there. Beastly.
    BIG NEWS:
    SpaceX Starship Users Guide (PDF)...
    Wow....
    Bullet points,
    * Payload and Propulsion modules are modular, both vertically integrated.
    * Payload and Propulsion modules can be swapped in & out.
    * Integration: "Payloads are integrated into the Starship fairing vertically in ISO Class 8 (Class 100,000) cleanrooms"
    * Payloads: "The uncrewed Starship allows for the transport of satellites, large observatories, cargo, refueling tanks"...
    So, the tanker won't necessarily use residual props from launch but also props in separate tanks. BIG tanks.
    * 2 standard payload bay configurarions:
    Standard: 8x17.24 meters
    Extended: 8x22+ meters
    Custom lengths available (!!)
    Standard bay
    Payload Mass
    * "Chomper" payload deployment: standard interfaces, tilting deployment table.
    * Co-manifesting
    - 1-3x geosynchronous telecom satellite(s)
    - Full constellation of satellites on a single mission
    - 1-2x geosynchronous telecom satellites plus rideshare system of small satellites
    - In-space demonstration spacecraft that remains integrated with Starship and returns to Earth
    - Cargo and crew configurations
    * Space Shuttle 2.0: "Fully-reusable Starship and Super Heavy systems are expected to allow for space-based activities that have not been possible since the retirement of the Space Shuttle and Space Transportation System or have never been possible before."
    Whew....
  4. #139
    Apr 2001
    Westland, MI
    26,163
    Jeff Foust @jeff_foust
    Looks like the FAA NOTAM is posted for a SpaceX Starship SN3 static fire test as soon as Wednesday:
    https://tfr.faa.gov/save_pages/detail_0_1989.html
    12:24 PM - Mar 30, 2020
    https://twitter.com/jeff_foust/statu...61724705423362
  5. #140
    Apr 2001
    Westland, MI
    26,163
    They lost SN-03 to a test setup problem. This was not a design/build issue.
    SN-04 is preparing to be stacked.
    https://twitter.com/elonmusk/status/1246677676733104130
    Pranay Pathole @PPathole
    Elon, it seemed like CH4 tank was filled and the LOX tank which was not filled collapsed because of the weight.
    Elon Musk ✔ @elonmusk
    Pretty much. Good news is that this was a test configuration error, rather than a design or build mistake. Not enough pressure in the LOX tank ullage to maintain
    |There are redundant pressure control valves. It’s a new system and SN3 was simply commanded wrong. Rockets are hard.
  6. #141
    Apr 2001
    Westland, MI
    26,163
    Hoping to pressure test Starship test article SN-04 tomorrow, April 25. FAA has issued a NOTAM (notice to airmen) for a test hop to 1500 feet in about a week.
    SN-05 has moved into the High Bay for stacking, and SN-06 parts are being built.
  7. #142
    Apr 2001
    Westland, MI
    26,163
    On to mounting the Raptor engines and at least one static fire.
    "SN4 PASSED CRYO PROOF! "
    https://twitter.com/elonmusk/status/1254632509863866368
  8. #143
    Apr 2001
    Westland, MI
    26,163
    2 days, 2 static fires of SN-04
    SN-05 (being stacked) and SN-06 (parts being produced) are in the wings, and requests are in to FAA for flight clearances; a 150m hop and a 20km jump.
    Tonight's
    https://twitter.com/austinbarnard45/...02927283912704
  9. #144
    Apr 2001
    Westland, MI
    26,163
    SN4 passed high pressure (7.5 bar) & engine thrust load at cryo
    https://twitter.com/elonmusk/status/1259344535991140352
  10. #145
    Apr 2001
    Westland, MI
    26,163
    Notice To AirMen at Boca Chica, ops leading to a static fire using Raptor s/n 20.
    Tuesday May 12 to Thursday May 14
    Window: 1000 to 2200 Eastern
  11. #146
    Apr 2001
    Westland, MI
    26,163
    Buckle up kiddies...
    1 hour after today's successful SN-04 static fire with a 25 tonne mass simulator, the FAA issued a 2 year suborbital RLV launch license. This is for any number for Starship missions.
    https://t.co/ksyfzc4Gj1?amp=1
    Monday's NOTAM is for up to 26,000 feet.
    Also; they'll be removing the flare stack, replacing it with a condensation unit so they can trap & liquify vented methane instead of burning it.
  12. #147
    Super MURCer MultimediaMan's Avatar
    Sep 1999
    Bentonville, Arkansas, USA
    1,891
    It went Ka-Beauuwm... rather spectacularly...
  13. #148
    Apr 2001
    Westland, MI
    26,163
    Looks like the GSE let go during de-tanking, perhaps damaged by the static fire, and methane pooled under the stand. Once that happens a boomski is inevitable.
    On the bright side, they were going to redo the GSE anyhow to add re-condensing vented methane, there's a second test stand mostly built, and SN-05 is already stacked in High Bay 1.
  14. #149
    Apr 2001
    Westland, MI
    26,163
    SN4 boomski,
    Joey Roulette @joroulette
    Elon Musk, leaving the KSC press site just now, said of yesterday's Starship test in Boca Chica Texas: "Unfortunately what we thought was going to be a minor test of a quick disconnect ended up being a big problem," referring to the explosion.
    https://twitter.com/joroulette/statu...84468322811905
  15. #150
    Apr 2001
    Westland, MI
    26,163
    High Bay 2 (Super Heavy) coming soon
    This fits with high construction activity at the Super Heavy pad site.
    Giant high bay coming soon
    Chris B - NSF @NASASpaceflight
    Replying to @elonmusk
    Oh my! And we thought the High Bay currently being used to stack Starship was impressive. Something for Super Heavy stacking I assume? KSC VAB scale?
    Yeah, for Super Heavy stacking
    https://twitter.com/elonmusk/status/1269419405856763906
