Results 1 to 9 of 9
Thread: FIC VA503+ and AGP card problem
    bence
    Guest
    Default FIC VA503+ and AGP card problem
    First, excuse me for my English.
    Second, excuse me, because I have not a Matrox grathic card, "only" an ATI Rage Fury.
    Who can say me, what is the problem, when the games with DirectX and/or Direct3D support freeze after few seconds of gaming?
    Please, write me, what is the correct setting in BIOS (FIC VA 503+ rev 1.1a) for correct AGP support, which version of VIA drivers are best for correct AGP 2x support, what is the order of drivers installation?
    I tryed (IMHO) everything, i.e. reinstalled the PC, changed the CPU setting from 3x112 to 3x100 MHz, changed all drivers for VIA and ATI, reinstall DirectX 6.1, but the games are still freeze. But only the games!!! The simply 2D applications are working perfect (in all resolution and all color depth).
    What is the solution?
    Thank You.
    Alex
    AMD K6-2 300@333 (3x112), 64 MB PC100 RAM, ATI Rage Fury 32 MB w/TV Out, 4 GB WD HDD, 17GB Maxtor HDD
    Steve C
    Guest
    Hi Alex,
    The best way to install the VIA drivers is to download their all-in-one driver updater. Just run it, and it will update all required drivers.
    I don't have a FIC ss7 mobo, so I can't help there. But what I have found out over the last couple of days is that I installed a Rage Fury, and it keeps overheating! Take the lid off your PC, and try again.
    Cheers,
    Steve
    Yeah, you know the score...
    (ICQ: 29468849)
    bence
    Guest
    I tried the latest all-in one driver for VIA from 7/20/99, but the problem was not solved.
    I repeat: all works perfectlyin simple 2D applications. The problem is only with Direct3D.
    Alex
    Super MURCer Wombat's Avatar
    Aug 2000
    DENVER, CO
    9,722
    Do you have any IRQ conflicts? The video card will tax the bus much more in 3D than 2D, and that's when such conflicts become evident.
    In your BIOS, you should probably turn off Read Around Write and Write Cache Pipeline.
    Also, try to go for AGP 1x, instead of 2x. It's much more stable for some systems, and I sincerely doubt you will notice a difference between the two.
    Disable AGP 2X in the BIOS, and install the VIA AGP driver in normal mode instead of turbo mode.
    Good luck,
    Wombat
    503+ rev 1.2a, 128MB PC100 RAM, K6-2/350@400,RH6 & Win98,G200 Millenium (SGRAM), no plans to buy a G400
    Aug 2000
    DENVER, CO
    9,722
    You do have an IRQ reserved for VGA in your BIOS, right? There's an option for that somewhere, and sometimes (depending on BIOS version) it defaults to "off".
    -Wombat
    bence
    Guest
    Thank You, Guys. the problem was in BIOS setting:
    I turned off Read Around Write and Write Cache Pipeline, and finally the card works corretly without hanging in 3D mode!
    I dont changed the AGP 2x to 1x, work fine with 2x AGP.
    Thank You once more.
    Alex
    Sep 1999
    Atlanta, Georgia, USA
    480
    Sim City 3000 still locks up after about an hour and I've tried all the solutions above. Mechwarrior 3 also crashes occasionally as well. I'm not sure Direct X 6.0 or 6.1 are fully compatible with SS7 and the G200 4.26 drivers I still use. These are the only two games that give me problems. Everything else works fine. I know I need to upgrade my G200 drivers and now that I've upgraded the G200 bios to 2.3, the newer drivers should work. the 4.26 ar ethe only ones that worked with the older 1.6 bios.
    RAB
    FIC503+1.2a,bios115je33;AMD K6-2/350;128MB PC100;Myst G200,bios2.3,drivers4.26;Win98;no OC
    mikehdft
    Guest
    RAB
    You may have heat problems. The K6-2 and G-200 both produce alot of heat. Remove the cover and if works O.K. you have found your problem.
    If its heat add a case fan.
    Mike H.
  9. #9
    Sep 1999
    480
    Mike,
    Thanks for the idea, but I don't think heat is the problem. That was one of my first guesses about the problem. When the games fail, I can do a restart without turning the machine off and everything works again. If it was heat, I would think a restart would not be effective.
    But I will keep a look out for heat, because there have been times when I couldn't get it to restart at all, but turning it off for a couple of hours fixed the problem.
    Its not that serious, but it is annoying. So for now, I just live with it.
    Thanks again
    RAB
  1. Help - G400 Dual Head (AGP) and FIC FB11 Mobo
    By Planar181 in forum Matrox Hardware
    Last Post: 15th May 2001, 15:53
  2. No AGP=2X, G400, FIC VA503+
    By erniecc in forum Matrox Hardware
    Last Post: 9th February 2001, 14:39
  3. AGP 1x/2x on FIC KA6110
    By Oleg V. Kuzmin in forum MURC Gaming
    Last Post: 13th September 2000, 16:11
  4. 4 Meg Apeture, G400 and Windows 2000 problem:FIC's response
    By jediphoenix in forum Matrox Hardware
    Last Post: 16th March 2000, 17:39
  5. Replies: 2
    Last Post: 26th November 1999, 09:46
