Results 1 to 8 of 8
Thread: Max USB & PS2 cable length ?
    Super MURCer TransformX's Avatar
    Sep 2003
    Behind you
    4,991
    Question Max USB & PS2 cable length ?
    Does anyone know the maximum cable length possible for USB and PS2 devices before the signal is too degraded ?
    Depends on the device/mobo you are using! I do not recomend usb cabel lengths over 5m!
    Super MURCer Kurt's Avatar
    Feb 2000
    Brussels, Belgium
    1,893
    For USB 2.0 I think it's 5m, then you need to use an active hub (ie with its own powersupply). You can link 5 of them.
    USB 1.0 cable are less shielded than the USB 2.0 ones, the max length should be about 3m before using a repeater (active usb hub). You can also link max 5 hubs.
    I'm not sure about the max length for PS/2, but it should be anywhere between 15 to 30m.
    Moderator az's Avatar
    Feb 2001
    Berlin, Germany
    10,122
    It's a timing issue, not a signal degradation issue! I don't know whether a hub will do, there are repeaters out there though... for long lengths I bet there is something like USB over ethernet converters.
    Super MURCer Marshmallowman's Avatar
    Sep 1999
    Perth,WA,Australia
    3,490
    I have a 5 metre usb cable, which I think is the max(without repeaters).
    It works by itself, but if I plug it into a powered usb 2 hub, it will sometimes have problems working reliably with my logitech rumblepad(usb 1).. eg 5 metres IS on the limit
    Super MURCer Fat Tone's Avatar
    Sherwood Forest
    8,456
    I have two 7+ metre USB cables (one for a printer, one a scanner, both USB2.0) connected directly to USB2.0 ports on my motherboard without issue.
    I have a couple of USB to ethernet convertors laying around - Scan were giving them away with large orders at one point. I think they cost around £15.
    I friend is using a 1.5m extension for her PS/2 keyboard and is having intermittent problems.
    FT.
    Feb 2001
    Berlin, Germany
    10,122
    Oh, have a look here. Always trust Mr. Rutter to already know the answer
    Feb 2001
    Berlin, Germany
    10,122
    here is a USB repeater with 5 m cable, in german, unfortunately. It is cheap (6.85 EUR), only does USB 1.1, and up to five can be used for a maximum length of 25 m.
  1. File Name Length, Folder Name Length, and Path Length
    By High_Jumbllama in forum General Hardware/Software
    Last Post: 15th April 2009, 23:36
  2. Data tranfer USB Cable
    By Debbie in forum General Hardware/Software
    Last Post: 29th November 2004, 02:04
  3. -=-=-> Cable Length <-=-=-
    By Yullin in forum Matrox Hardware
    Last Post: 21st June 2002, 08:35
  4. Firewire cable length limit
    By bill2 in forum Desktop Video
    Last Post: 17th February 2002, 04:49
  5. Cable-length between G400 and monitor/TV
    By Carla in forum Matrox Hardware
    Last Post: 8th July 1999, 05:04
