Finaly SCART RGB TV-out with Matrox P750/Parhelia works !!!
    If the G400 knows there is a TV connected, it should not allow to change the frequencies because of the risk of explosion of some older TV (wich have no scan protection). The G400 must believe it's a monitor.
    For your question, it's a really good question and I will try as soon as possible (my HTPC has now a P750). I have to do some work to test. It's driver related and I don't know how interlaced video is handled on interlaced monitor (not managed with the TV chip).
    A64 3500+ NewCastle @2550 (FSB 255, 10X)
    Abit AV8 v1.1 bios 1.7
    2X256 MB Crucial Ballistix PC4000 (1T Cas 2.0, 2-2-6) @DDR333/FSB255=212MHZ
    LC Power 550 W
    Geforce 6800 GT (Asus V9999GT-TD /128) @428/900 + nvSilencer 5 rev.2
    Thermalright XP-90 + Enermax 92mm fan
    NEC 3520A DVD-RW Firmware 3.04
    SB Audigy 2
    BELINEA 10-17-30
    XP Home SP2 - Via Hyperion Pro 5.00A
    Via IDE accelerator Driver 1.21 Beta
    Via RAID 4.30C driver Via velocity V23 Network driver
    3DMark05=5024 3DMark03=12508 3DMark01=24352 AquaMark03=70712
      Just tried with my P750 (must find the time to rebuild the setup with the G400) and it's not good. The interlaced contents are not well rendered on TV. The frames are not correctly synchronised with the TV sync. But it's in VMR9 mode not in overlay mode (the overlay mode is buggy with interlaced output on my P750).
      The P750 is bad with interlaced streams. The G400 is certainly better, but I doubt that Matrox put into the G400 drivers a correct sync. of interlaced video streams with interlaced monitors (not TV-out managed with a special chip) (but this has to be tested).
      In fact I have not a lot of interlaced files to test. I only watch progressive PAL DVDs with my setup, and for this application, th P750 is OK.
      LC Power 550 W
      SB Audigy 2
      BELINEA 10-17-30
        Very nice thread, very interesting !
        Thanks a lot for working this out.
        Bravo.
        System : ASUS A8N SLI premium, Athlon 64X2 3800+, 2Gb, T7K500 320Gb SATAII, T7K250 250Gb SATAII, T7K250 250Gb ATA133, Nec ND-3520, Plextor PX130A, SB Audigy 2, Sapphire Radeon X800 GTO, 24" Dell 2407WFP.
          Yay! Great job greinedo... I bet a lot of people owe you a beer now.
          _____________________________
          BOINC stats
            Thank you greinedo for your great job that makes murc that special spot for us, matrox owners; it's due to guys like you that many new improvements have been made, even on matrox drivers. I hope that those from us that have more experience on this matters can contributte on a constrictive way to keep this place as good as it have been the last years, and a reference site in the web on this area
            Asus A8N-E
            Opteron 146
            2x512mb Gkill
            Seagate SATA 120 gb
            Plextor Premium/LG GSA-4167B
            Matrox Parhelia APVe
            Echo Mia soundboard
              Thanks a lot
              Hope there will be some interesting hardware this year to speak and tweak about in this great virtual place with so many interresting people and minds.
              Regards
              A64 3500+ NewCastle @2550 MHz
              Abit AV8
              2X256 MB Crucial Ballisticks
              Matrox P750
              SB Audigy 2
              Onkyo TX-SV525 AV amp.
              Mulidyne R+L, Yamaha F+RL+RR speakers
              DIY 60 kg 125 L subwoofer...
              LC Power 550 W
              SB Audigy 2
              BELINEA 10-17-30
                Maybe you'll have some work to do whith the HDTV output of the PCI express Parhelia
                check your PM
                  Yes, interresting card, but I have to change then my motherboard also, and I just bought it a few days ago ...
                  LC Power 550 W
                  SB Audigy 2
                  BELINEA 10-17-30
                    Anyway buyign this card just for the HDTV output would be way too much. It's still the "old" Parhelia design
                      I have posted the following on the official Matrox Technical Forums under P-Series and SCART RGB of Industry Chat. http://forum.matrox.com/mga/viewtopi...r=asc&start=15
                      "My post is just information for enthusiasts. I can do what kine has did. The television acts as a fixed frequency RGB computer monitor. It is 15.6KHz horizontal and 50Hz (PAL) or 60Hz (NTSC) vertical.
                      However, because PowerDesk assumes your television is a computer monitor, you can only use a DVDMax resolution of 640 x 480 but not 720 x 480 or 720 x 576. This is because you cannot force DVDMax to use other resolutions for computer monitors as explained in many of the forums where people try to change the DVDMax resolution.
                      I normally use S-Video as it's much easier and is great for movies. However, when it comes to sharp text or graphics such as colored subtitles and desktop display, the color tends to bleed as the color signal is compressed. This is explained at http://tvtool.info/english/rgb_chrontel3_e.htm (The site is about TV-Out on NVIDIA based cards.)
                      In addition to what henk53 had said, you may wish to know that the European Gamecube does NOT have S-video output! You can only use composite RCA or RGB SCART! The US version is opposite having s-video instead of RGB. I've heard this from many sources such as GameFAQs. (They don't like hotlinking to files so I can't provide it.)
                      I use RGB SCART for my DVD player, digital boxes and my Super Nintendo. I use S-video for my Matrox P650 and composite for the "out-dated" video cassette recorders."
                      I have tried Zoom Player and cannot get it to display the video on my TV. I want some software which could replace DVDMax and I want to to be effortless since I want my PC to be operable by non-technical users too. Sorry but I'm only a begginner.
                      JackElectronics
                      My Matrox SCART Users Support Page:
                      http://www.jackelectronics.f2s.com/c...rox/index.html
                        Hi jackelectronics !
                        To answer your question (at Matrox official forum), my username is greinedo here at murc, and kine there at Matrox. I'm the beginner of this topic speaking about connecting a Matrox P750 to TV via SCART RGB.
                        As I said there, because of the not adjustable resolution of DVDMax, and the need to drive the TV as a fixed monitor in 720x576, I gave up using DVDMax and even Overlay features.
                        Moreover, I found that with some Powerdesk-hf drivers, overlay video playback is corrupted on interlaced monitor surfaces. So overlay was an issue (it seems that it's better now with the latest drivers 1.8.0.133).
                        For those reasons you need to find a DVD player that can play fullscreen on the second head, without touching the resolution, and in VMR mode.
                        Zoom Player is such a player, but I agree it's not easy to make him work at first. But after configuration he can detect a DVD insert and start the video on the second head fullscreen, without any trouble.
                        What is your Matrox card connected with SCART RGB to the TV ?
                        If you still want to try Zoom Player with your setup, I could start such a topic "Making Zoom Player to work..." on the Home Theater and HIFI Forum here at MURC.
                        LC Power 550 W
                        SB Audigy 2
                        BELINEA 10-17-30
                          Hi,
                          I have a Matrox P650 connected to my TV via a S-video connection. As I am used to single display computers, I only use my 19" CRT monitor at 1600 x 1200 @ 85Hz. Therefore, my TV remains off when I am not playing video. Oh, why not start a topic about Zoom Player and HTPC.
                          Jackelectronics
                          JackElectronics
                            I made a small explanation in the Hifi and HTPC forum.
                            Rendez-vous ici: http://forums.murc.ws/showthread.php?s=&postid=526505
                            LC Power 550 W
                            SB Audigy 2
                            BELINEA 10-17-30
