Hello.
I've got a dual-head (DH) G400MAX that I'm running on a RedHat v9 system with the current Matrox drivers for this card. Until now I've never actually had a need to use the second head. Now I do. Mind if I ask a few questions?
1. Is it possiple to direct the output of a specific application to the 2nd monitor?
2. Do the resolutions on both monitors have to be the same? How about the pixel depth? Refresh rate?
3. I have an application the uses direct writes to video memory (the app uses the SVGALib library rather than XFree86 calls for displaying). Can the DH still work with direct writes to video memory? How do I know what address in video memory will be reflected on a given monitor?
4. Is there any further reading I can do to get up to speed on the using DH with a G400MAX in XFree86 v4.3.0?
Thanks.
