Upgraded, 1.2GHz difference, 650 3Dmarks difference is something wrong?
  • Upgraded, 1.2GHz difference, 650 3Dmarks difference is something wrong?
    I transfered my Parhelia (b) and HDD to my new rig (Dual Athlon @ 2.26GHz, Tyan TigerMPX, 512MB of ECC registered)
    The Celeron 1.1@1.47 scored 6480 3DMarks, this rig only 7130.
    I'm wondering if this score is normal or something isn't installed properly. (Not that I care, I just want to be sure everything is dandy).
    WindowsXP SP1a, DX9.0b, 1.4.3 drivers, all crytical patches
    Installed lattest AMD AGP and bus master IDE drivers.
    So am I hitting GPU wall or did I bork something?
    Sounds about right for a Parhelia bulk...
    Let us return to the moon, to stay!!!
      Everything looks good. If you want more marks buy a Radeon.
        If you want an accurate comparison, it might be good to know just WHAT version of 3DM you are using...
        Core2 Duo E7500 2.93, Asus P5Q Pro Turbo, 4gig 1066 DDR2, 1gig Asus ENGTS250, SB X-Fi Gamer ,WD Caviar Black 1tb, Plextor PX-880SA, Dual Samsung 2494s
          It's not 03 by looking at his scores.
            3DMark 2001SE, build 330.
              Hey Utwig! You did the P750 score graphs here in the benchmarks section (http://forums.murc.ws/showthread.php...highlight=p750), didn't you? An AthlonXP 2400+ with 333DDR scores about 7212 points, so I think your result is pretty correct.
