Help. Need advice RGB TO VGA
  • Help. Need advice RGB TO VGA
    I have 2 screens
    1. LCD 15" PRIMARY
    2. IIYAMA PRO 512 22" CRT SECONDARY
    Want to watch DVD on secondary, and also have my digital cable box plugged into PC / direct into secondary monitor. The cable box has RGB out/ composite. My secondary screen has 2 inputs (DB 15)
    How do i achieve this with reasonable quality / good price.
    Thanks
    Peter
    Found this it seems ideal but it is 500 quid. i want to spend less than that.
      You could get a video capture card...
      Asus P4C800-E Deluxe, Pentium 4 3GHz, 2Gb DDRRAM, Gainward BLISS GeForce 7800 GS+ 512MB, Matrox TripleHead2Go Digital, 3x Iiyama 4637 18.1" TFTs, Audigy 2 ZS, Matrox RT.x100, Silentmaxx Acoustic Case
