Download here;
PIP Collection
Now extract the PIP.mvp file. Place it in a new folder whereever you care then open MSPro, right click on the Moving Path catagory and select LOAD to import the file.
You'll now have 7 new moving paths;
Left top, right top
Center, top center, bottom center
Left bottom, right bottom
Just load the clips to be PIP'ed each to its own overlay track, put a nice still or animation in Va as the background and apply the PIP effects as required.
They are set up for 180x120 in a 720x480 DV frame, but should scale correctly for other frame sizes. They will also be inside the title safe margin.
You can also adjust the PIP's size and position as needed. Once ADD'ed to the PIP list the file can be re-saved with your new versions in it.
Enjoy....
PIP Collection
Left top, right top
Enjoy....
