Results 1 to 5 of 5
Thread: Need help with G200 BIOS
    Default Need help with G200 BIOS
    I have a MGA-G200 that propably has the BIOS somehow screwd up...
    The problem is that the card won't output anything during post.
    The motherboard is the Asus P5A with Ali Alladin V chipset.
    I tried updating the BIOS with the BIOS utility but it gives an error: Unable to get eeprom information.
    The BIOS at the moment is 2.3-11 according to the utility
    I also tried running the diagnostic tool and it gave the following error: Primary BIOS not identified
    And no, I do not have a BIOS recovery disk...sorry
    Is there any way to repair the damage that has been done?
    Super MURCer KeiFront's Avatar
    Sep 2001
    Belgium
    2,679
    Try the restore bios utility on the matrox website http://www.matrox.com/mga/support/dr.../ftp_util2.cfm
    "For G100, G200 and G400 series graphics cards only.
    This utility will restore your Matrox Graphics card's BIOS to the factory settings. Please read the readme file before downloading."
    Main: Dual Xeon LV2.4Ghz@3.1Ghz | 3X21" | NVidia 6800 | 2Gb DDR | SCSI
    Default No luck with bios recovery disk
    Tried the BIOS recovery disk and recognizes the g200 ok but says: flash failed..
    I'm starting to think that the card is useless...
    I'm open to any suggestions though
    Default No luck with BIOSPROG
    Tried updating the BIOS with BIOSPROG but no luck. it just wouldn't flash. Gave an error and instructions to send the error message to some email adress. I give up...
    Thanks for the help anyway
  1. g200 bios
    By bardos in forum Matrox Hardware
    Last Post: 30th January 2006, 15:05
  2. Should I upgrade my G200's BIOS?
    By Ovi in forum Matrox Hardware
    Last Post: 27th August 2000, 11:45
  3. Can't re-flash G200 Bios?
    By Mellow_Dude in forum Matrox Hardware
    Last Post: 16th December 1999, 03:59
  4. G200 - which drivers, Bios?
    By batman in forum Matrox Hardware
    Last Post: 27th September 1999, 23:45
  5. OH, NO!!! Something ate my G200 BIOS!
    By billko in forum Matrox Hardware
    Last Post: 25th September 1999, 11:40
