Results 1 to 13 of 13
Thread: matrox g220 card help please
    Oct 2001
    uk
    7
    Default matrox g220 card help please
    hi i got a big problem
    on my matrox card i some how erased the bios
    now is there a way to get my card to work
    i have tried PROGBIOS.exe but have not got a clue what do with it
    can some one help me out
    this is what i did made a disk try to flash the bios
    but it says vga disable and some thing about the input file not there i think thats the bios
    can some please give me step to step guide please.
    forgot to say nice board
    thanks for ur help
    asus007
    Jeepin' to the grave Kruzin's Avatar
    Casper, Wy, USA, Earth
    6,527
    Welcome aboard
    Your problem is not an uncommon one (unfortunatly).
    You can go to our files section, and download Matrox's BIOS recovery utility. Instructions on how to use it are in the readme file:
    http://www.murc.ws/BiosMatroxUtils.html
    Core2 Duo E7500 2.93, Asus P5Q Pro Turbo, 4gig 1066 DDR2, 1gig Asus ENGTS250, SB X-Fi Gamer ,WD Caviar Black 1tb, Plextor PX-880SA, Dual Samsung 2494s
    Oct 2001
    uk
    7
    can u tell me how and were to use PROGBIOS.exe
    i have tried it in dos but no luck please help
    thanks
    6,527
    Lightbulb
    Did you download the recover utility I listed, and follow the directions outlined in the text file?
    You don't need to mess with progbios directly. Recover.exe will create you a boot disk that will fix the card for you.
    Oct 2001
    uk
    7
    i tried but no luck i have matrox mystiqe 220
    but i think the boot file will not support the mystique i can be wrong so is there any othere way what can i do now
    thanks
    Oct 2001
    uk
    7
    this is what it says in progbios
    warning : invalid bios
    warning : can not find pins structure
    mystique 220
    warning invalid pins offset...
    vga disabled- bios
    warning cannot open bios input file
    what do all this mean is there a way around this
    i have tried every thing now
    heeeeeeelp
    6,527
    Ahhhhh.
    A Mystique220.
    Your topic title says "G220", which I thought was a typo, and that you meant G200.
    Mystique220 is not a G series card, so that recover util will not work on it. It's just for G series cards.
    Mystique220 came before G100/200/250/etc.
    What BIOS/biosprog are you using? It's possible you have the wrong one, if you where under the impression your card is a G series. You should be using the April '99 setup3.51 package available here:
    http://www.murc.ws/cgi-bin/dl.cgi?si...l=setup351.exe
    Oct 2001
    uk
    7
    sorry to be so thick is there recovery zip for this card
    also can u please send me the right file that i need
    my email is
    schand7@aol.com
    also what about the pins ?
    thank u this is my first time so i have not got a clue
    thanks for all ur support
  9. #9
    6,527
    Just click the link in my previous post to get the file you need, unzip it, and follow the instructions in the readme file...
  10. #10
    Oct 2001
    uk
    7
    ok now
    i get a warning saying
    the bios protection switch is currently set to protected
    what do this mean what can i do ?
  11. #11
    6,527
    Hmmmm.
    That card didn't have a BIOS switch.
    After consulting with Haig (Matrox's tech support manager), it sounds like you need to contact them for a bin file:
    He's gotta call us so that we can send him a bin file and then use progbios to re-flash it.
    Post your problem in Matrox's own forums, ask them to send you the bin file you need, and refer them to this thread.
    http://forum.matrox.com/cgi-bin/mgaf...i?action=intro
  12. #12
    Oct 2001
    uk
    7
    can i find it any were on the net (bin) do u no the name of this bin file? can u get this file for me i have not got a clue
  13. #13
    Super MURCer Rags's Avatar
    Casper, WY
    4,052
    Go to the link Kruzin gave you and ask for the file, they will help you out.
    Rags
  1. Matrox Card for Collectors ... Matrox MVP
    By DC in forum MURCs Happy Shopper
    Last Post: 29th March 2005, 11:33
  2. Next Matrox card
    By UtwigMU in forum The Crystal Ball
    Last Post: 8th March 2004, 00:39
  3. Soundblaster sound card VS Matrox video card
    By DGhost77 in forum General Hardware/Software
    Last Post: 14th March 2002, 23:51
  4. New Matrox Card !!!!!
    By X-Caliber in forum Matrox Hardware
    Last Post: 13th January 2002, 21:58
  5. How does the Matrox Card Know ???
    By numatrox in forum Desktop Video
    Last Post: 8th October 2000, 20:25
