Cable/DSL routers...need suggestions
  • Cable/DSL routers...need suggestions
    Well i'm going to be sharing my cable modem with everyone else in house, so I need suggestions for Router..I'm looking at D-link and Netgear products right now...so if anyone has any experance with these products it would be much appereated!
    Scott
    I can recommend the Linksys BEFSR41.
      Ditto. I run the LinkSYS and it's very good. With the new downloadable firmwares it is probably the most feature packed as well.
      Jammrock
        Make it three. I've been running the Linksys BEFSR41 for over a year and it's one great box.
          Ditto 4........ 4 Port Hub, compact and very easy to setup.
            If you already have a hub/switch this is a cheep and easy to set up alternative!
              Yup, same here
              chuck
                Yet another satisfied Linksys Router user.
                  WOW!!!
                    I *think* Linksys should put this thread in their ads
                      I guess I'll throw my vote in for Linksys too. The only problem we've had was it losing the connection to the DSL modem, but all we have to do is turn it off for a few secs. It only happens once every few months. Although I don't think we've updated the firmware in a long time.
                      Has anyone used the wireless model?
                      Gigabyte GA-K8N Ultra 9, Opteron 170 Denmark 2x2Ghz, 2 GB Corsair XMS, Gigabyte 6600, Gentoo Linux
                      Motion Computing M1400 -- Tablet PC, Ubuntu Linux
                      "if I said you had a beautiful body would you take your pants off and dance around a bit?" --Zapp Brannigan
                        Whilst I have never used the Linksys router I can't really praise it like everyone else. I can however tell you to stay the heck away from the D-Link router. I dunno which model you were considering, but the one I used to use (till it died out of nowhere) sucked in every way. It was constantly disconnecting me for no reason, and it made online gaming a joke. I still use D-link NICs, with nay a problem, but their routers are trash.
                          alternative
                          SteveC started a thread on this back around June. As a result I bought the Netgear RT314 for about £100 - it was pretty easy to set up, but there are certainly ones that are easier.
                          Tony.
                          FT.
