Results 1 to 3 of 3
Thread: g200clk. What am i doing wrong?
    Fathead
    Guest
    Default g200clk. What am i doing wrong?
    If i type in g200clk /2 1 0 0 2 0 0 0 0 0 0, i get the following values.
    casltncy: 3
    rrdelay : 1
    rcdelay : 2
    rasmin : 5
    rpdelay : 2
    wrdelay : 1
    rddelay : 0
    smrdelay: 1
    bwcdelay: 1
    bpldelay: 1
    I thought that i would get values of
    1 0 0 2 0 0 0 0 0 0.
    Why is this? Am i just stupid?
    Also, when you type g200clk you get a summary. one line says:
    System PLL Parameters: M=16, N=125, P=0, S=3
    What does all this mean?
    I'm totally confused.
    Arkansas - at least it's not Mississippi
    167
    1 is not always 1... it depends on what the programmer wants it to mean. In this case, it represnets options.... 0 = option (speed) 1, 1 = speed 2, etc. More than likely just a "carry over" of binary "on / off" switching. If you really want an explanation of the PLL parameters, check out MatroX Files: http://grafi.ii.pw.edu.pl/gbm/matrox/ For the purposes of using g200clk, you don't really need to worry about it... if you are like me, and just like to know these things, check the site out thoroughly.
    Fathead
    Guest
    Thanks for the explanation Anid.
  1. G200clk reports wrong speeds??
    By Maniac in forum Matrox Hardware
    Last Post: 6th August 1999, 18:15
  2. g200clk termination
    By Fatebender in forum Matrox Hardware
    Last Post: 29th July 1999, 11:39
  3. Powerstrip or G200clk?
    By dj911 in forum Matrox Hardware
    Last Post: 23rd July 1999, 01:50
  4. problems with G200clk
    By overclokked in forum Matrox Hardware
    Last Post: 22nd July 1999, 07:22
  5. PD 5.13 and G200CLK
    By GerryD in forum Matrox Hardware
    Last Post: 5th July 1999, 07:48
