Changing G400 DualHead to G400 MAX through pins
  • Changing G400 DualHead to G400 MAX through pins
    Hi all you murc'ers!
    I've changed the clock frequences of my G400 DualHead to match a G400 MAX... the pins goes like this:
    ;MGA Bios Programming Utility v2.18.000d
    ;(C) Matrox Graphics Inc. (2001)
    Fill: 0 127 0xFF
    ;Matrox G400 AGP
    ;VGA Enabled - BIOS V2.1
    0 2 0x412e
    2 1 0x80
    3 1 0xff
    4 2 0x0401
    6 2 0xca93
    8 2 0x0009
    10 2 0x0300
    12 16 'xxxxxxxx'
    28 6 '104'
    36 2 0xfff0
    38 1 90
    39 1 90
    40 1 90
    41 1 90
    42 1 90
    43 1 90
    44 1 34
    45 1 34
    46 4 0
    50 1 0x3f
    51 1 0xff
    52 1 0xff
    53 1 0xc2
    54 1 0xff
    55 1 82
    56 1 41
    57 4 0x0190a419
    61 4 0x24045491
    65 1 150
    66 1 75
    67 4 0x019b8419
    71 4 0x24045491
    75 1 150
    76 1 75
    77 4 0x019b8419
    81 4 0x24045491
    85 1 0xff
    86 2 0x0c88
    88 2 0x0c88
    90 1 0xee
    91 2 0x2cfe
    93 2 0xfff9
    :filetype TOUCAN
    :PCBinfo 906-01
    :SubsystemVendorId 0x2179102b
    The Information tab under Control Panel -> Display -> Settings -> Advanced shows that my maximum RAMDAC speed is 360 MHz. Also MGA Tweak tells me that my card is running 150 core/200 memory.
    Is it possible to alter the pins further to make the card (and the drivers as well) think it is a G400 MAX? I figured it would be something like changing pin 61, 71 and 81 from 0x24045491 to 0x20049911, pin 10 from 0x0300 to 0x0700 as well as changing the SUBSYS_ID from 2179102b to 0x217D102b?
    Best regards
    Rene Pedersen
    p3-800eb, asus p3v-4x, 256mb cas2 pc133, 32mb matrox millennium g400 dualhead, 20gb quantum fireball plus lm, 6x/32x pioneer dvd-a03s, sb live! value, 10/100mbit 3com 905b, 17" sony g200
    You need to change SUBSYS_ID value!
    The MAX SUBSYS_ID is 217d while the G400 standard one is 2179
    Edit your PINS and change SubsystemVendorId from 0x2179102b to 0x217d102b
    Now your board should be recognized as G400MAX!
    ATHLON XP 2600; Abit KX7-333Raid; 1GB SDRAM DDR PC-3200 Corsair XMS; Matrox Parhelia AGP 256; HITACHI 7K250 250GB; HITACHI 120GXP 120GB; HITACHI 120GXP 60GB; Sound Blaster Audigy 2; Plextor DVDRW PX-716A; Plextor CDRW Premium
      I ve a G400MAX and in the info tab it says Millennium G400MAX AGP! I think video drivers "read" what type of board you have not only from the core freq and SUBSYS_ID but also from the video memory.
      It s related to the board memory controller (PINS 61, 71, 81). Standard G400 uses 6ns SDRAM , while the MAX version have 5ns SGRAM. So you can t change PINS because they have different memory types.
        Venturer, you are wrong. The standard G400 uses SGRAM as well, only some OEM cards used SDRAM.
        Rags
          Hi Venturer!
          I've changed the SUBSYS_ID. I removed the Matrox Graphics Software from Windows 2000 and installed the drivers again. This time it recognized my card as a G400 DualHead MAX.
          But in the Information tab it says:
          Model: Matrox Millennium G400 AGP
          Shouldn't it say Matrox Millennium G400 MAX AGP?
            Can this be done with a Marvel too?
              Can what be done with a Marvel too ?
              You mean changing the clock and ramdac settings, I thinks you can.
                Where can i get the programs to do this stuff?
                like MGA Bios Programming Utility v2.18.000d
                and others?
                I do not know, do you?
                  and others?
                  The BIOS programming utility is included in the BIOS download from matrox, the dos programming utility included in 2.08 can NOT be run in windows, therefore u are better to find the 2.07 BIOS for its dos programming utility, which can be run under windows environment.
                    hello where can i change those pins ??? are they in the bios update files ???
                    specs p4 2.8@3.2Ghz Giga byte xnpbla bla 2x80GbHD Raid 0 creative audigy iiyama vision master 502 (21inch) a logitech mx700
                    video is ati 9700pro modded to 9800 speeds volt mod ect ect
                      Why bother?
                        hihih stil got a g400 and there coming a new one so i can burn this one heheh and maybe it works hehe
                          Could someone please expain me the whole process?
                          I've been using a G400 DH (not the MAX version) for almost three years now, mainly for productive work (photoshop, flash, dreamweaver, max 3D, etc) but I've played quite a lot of games (even the latest MOHAA, Renegade C&C, RTCW, Jedi II etc.) I have been using Matrox's own tech support tweak utility but I'd like to push the card a bit more before I replace it.
                          By following this process while my card perform like the MAX version? Will I need a fun for the chip?
                          I'm using W2K SP2 with all the latest Patches, Via chipset with the latest drivers, Beta 5.84 G400 drivers.
                          Thanks in advance.
                          P.S. Have been reading MURC forums for over a year now. Can be quite entertaining somtimes. Also I've learned a thing or two here.
                          Old rig:
                          PIII 533 Slot1, ECS P6Bat-a+
                          2x133MB PC133 Ram, Matrox G400DH 32MB
                          Quantum Fireball Plus AS 40GB
                          Quantum Fireball CR 13GB
                          Yamaha CDRW 8424, Hitachi GD2500BX, Eizo T760 19"
                          New one:
                          P4 2.8C, MSI 865PE-NEO2 LS
                          4x256 PC3200 Samsung Gold
                          Club-3D Radeon 9800PRO 128MB
                          Seagate Barracuda 7200.7 SATA 200GB
                          Sony DVD-RW DW-U10A, Sony DDU1613
                          Eizo T760 19", 2.1 Altec Lancing 2100
                          HP printer/scanner, Microsoft KB/mouse/joystick, Wacom Tablet
                          Antec Sonata Piano Quiet 380W case
                            Think twice before changing your G400 into MAX version. When you look at MAX, you'll se some difference from "classic" / the FAN!!!
                            While for most G400 boards it's possible to turn them into MAXes, you should complete the transformation by attaching a fan to the G400 chip heatsink.
                            • #15
                              wel okay my g400 isnt going for max mhz but i got no fan on it so is i put one on is it possible that i gat higher results ??? can someone tell me that else i going to buy one this weekend and pus my g400 to the max because a replacerer is on his way hehe geus which one that will be hehe
                              and another question where can i read my ramdac frequentie because i changed my pin nummmbers no it says in my info tab i got ramdac off 400 mhz max is that possible ???
                              ok i am off to my cold beer now and wait till the sun is going to sching and giving me that beautiful ph bla bla i find the name of the new card to hard get a new one please hehe lol its to hard after a few couple of beers
