Bus Mastring problems
  • Bus Mastring problems
    Half the battle is won...
    Finally I got my G400Max and SBLive! to work together (PD5.30 and LiveWare 2.1), however, in order to run Tech Demo I must disable bus mastering (crappy frame rate).
    Look around among previous postings and found some clues but I wondered if there is
    any optimum solution where it is not needed for reghacks etc.
    What about this Win98 file "VMCPD.VXD" that could be overwritten by DX6.1? Do I still have to replace it from my Win98 CD or?
    Greetings
    Baxman
    PIII 550, Intel SE440BX,
    128 MB pc100 RAM,
    SB Live!, Fuijtsu 17.3GB, AOpen 6xDVD, HP 8100i CD-RW, Mitsubichi Diamond 900u Pro 19" Monitor, Creative FPS2000 Speakers, Intel
    10/100 MBits network card, Matrox G400 Max
    128 MB pc100 RAM,
    SB Live!, Fuijtsu 17.3GB, AOpen 6xDVD, HP 8100i CD-RW, Zip 100 drive, Mitsubichi Diamond 900u Pro 19" Monitor, Creative FPS2000 Speakers, Intel
    Life's never easy - you'll need to try the reg hacks to force AGP1X blah blah. Unless anyone else has any ideas.....?
    The reghacks aren't difficult anyway!
    Cheers,
    Steve
    PS: Some or all of the above message may be wrong, or, just as likely, correct. Depends on what mood I'm in. And what you know. ;¬)
