Results 1 to 8 of 8
Thread: Voodoo II and G400MAX
    RickK
    Guest
    Default Voodoo II and G400MAX
    I have a G400MAx on order I have been useing a Voodoo II for most of my Gaming Half-Life ect. Should I leave this card in my system ? Will I have any problems with conflicts. Any input will be welcome. Thanks in advance, Rick
    Jeepin' to the grave Kruzin's Avatar
    Casper, Wy, USA, Earth
    6,598
    They should work together fine.
    But you'll see that (unless you play Tribes or Unreal religeously), that the Voodoo2 will get little to no use, so you may as well take it out.
    Super MURCer Maggi's Avatar
    Jan 2000
    somewhere lost in the middle of nowhere, LĂĽneburger Heide, Germany
    5,087
    but not before Unreal gets decent OGL and D3D support ... that game runs under glide.
    Cheers,
    Maggi
    Asus P2B-S @ 112MHz FSB - Bios 1009 final
    Celeron300A @ 504Mhz
    128MB 7ns SDRAM
    G400 DualHead 32MB SGRAM @ 201 MHz memory clock
    I'll be on holiday for the coming three weeks and I miss you folks already ;-)
    [This message has been edited by Maggi (edited 07-22-99).]
    Sep 1999
    Cornwall, Ontario, Canada
    49
    RickK:
    I too will be getting a Max and my Voodoo2 will be removed from my system. I haven't used it in quite a while. I much prefer my G200 for gaming especially using the S-video TV Out to a 33" Panasonic GAOO TV.
    If you have some Glide only games that you want to continue play the keep it. If not, remove it as it will just sitting there causing heat and blocking air-flow in your case as it is in mine. If you have a Max, you won't need it.
    BTW, a Voodoo2 card cannot cause a conflict as it doesn't use an IRQ. For that reason, on a BX based motherboard at least, it is a good candidate for PCI slot #1. AGP cards may be forced to share their IRQ with any IRQ-using card placed in that slot. AGP cards often don't like sharing so a non-IRQ card like a Voodoo2 is best placed there.
    Happy trails,
    P2-450;256MB PC100;Asus P2B;16MB G200 Mystique 5.13,2.3; 12MB CL Voodoo2;CL SB Live Full(LW2.1); ViewSonic 17PS; 10GB Maxtor 7200RPM UDMA2;3.2GB Quantum FB ST UDMA2;CL 2X Encore;USR 5686 External Sportster V.90;Win98;DX6.1;IE5a etc.
    Hey Maggi,
    Tell me, the G400 of yours is not a MAX, is it?
    Just wanted to know.
    Thanks,
    Joseph
    Fleabus,, I also have G200 and vd2 sli, and I have the exact opposite solution,
    G200 run fine with 2d game and vcd/dvd, but on 3d game, I use vd2 95 percent of the time, G200 can not even play a decent MS baseball, Flighter sim, motorcross, unreal, Falcon4, Monster Truck etc etc!
    G400 might be a different story!
    Sep 1999
    49
    smile:
    If you look at my sig you'll see that I don't have SLI. My system is very fast though and the G200 TV-Out to my set is terrific. The TV is also centred in a Surround system.
    Receiver: Pioneer Pro-Logic VSX-D901S
    125w/ch fronts; 55w/ch centre; 45w/ch rear.
    Speakers: Fronts - Cerwin-Vega! D-9 (4-8 ohm)
    1x15", 2x4", 1x1"
    Sensitivity 102db
    Centre - Paradigm CC-200 (6 ohm)
    2x5 1/2"; 1x3/4"
    Sensitivity: 92db
    Rear - Cerwin-Vega! 26 (4-8 ohm)
    1x12", 1x2.5"
    Sensitivity: 96db
    I'd much rather do my gaming with the TV where it is instead of looking off to the side to a 17"(albeit a good one) monitor.
    The G200 just looks so much better and doesn't seem slow to me!
    Happy trails,
    kettlerp
    Guest
    If you've got one V2, get a second from someone who tossed theirs out. I had one, then added a second from a friend of mine, got the hacked up Wicked3D drivers (for some reason you can't buy them anymore, dammit!), and WOAH NELLIE! Damm, V2 SLI at 1024x768 is FAST! And Unreal positively GLides across the screen, it's that smooth! :-)
    Anywho, I've also got a G200, but the G200's OpenGL support doesn't work. For some reason the Millennium II in my system confilicts with the G200 when it comes to OpenGL. The G200 is great for Direct3D, but as I play a variety of games, D3D support just isn't enough.
    Just my $0.02
    Primary System: PIII-540 (450@4.5x120), Soyo 6BA+ III, 256MB PC100 ECC SDRAM, Millennium G200 AGP, Millennium II, Voodoo2 SLI, Two Mitsubishi Diamond Pro 900u monitors, 3Com 3C905, ADSL Modem 640kbit down/96kbit up, SoundBlaster 32, Altec Lansing AC5 spkrs, 2nd Parallel Port, WD AC41800 18GB HD, WD AC31100 10GB HD, Toshiba XM-6102b CD-ROM, HP 8100i CD-RW, Epson Stylus Pro, Sharp JX-9400 LJ-II compatible, OptiUPS PowerES 650, MS SideWinder Precision Pro USB joystick, Logitech 3-button mouse, Mitsumi keyboard, Win98 SE, Belkin OmniCube 4-port KVM -- Secondary System: PII-266, Asus P2B BIOS 1008, 128MB PC100 ECC SDRAM, Millennium II, 3Com 3C590, 3Com 3C509, Mylex BT-930 SCSI card, Seagate 2GB Hawk, NEC 6x CD-ROM, Linux distro S.u.S.E. 6.1 -- Tertiary System: DFI G568IPC Intel 430HX chipset, P200MMX, 96MB of non-parity RAM, Millennium II, 3Com 3C900, SoundBlaster 16 MCD, Fujitsu 3.5GB HD, WD 1.2GB HD, OS of the week -- All specs subject to change on a whim. :-)
  1. Matrox Voodoo
    By The Viking in forum Matrox Hardware
    Last Post: 8th August 2001, 01:06
  2. Voodoo 5 Previews!
    By DosFreak in forum Matrox Hardware
    Last Post: 18th April 2000, 19:36
  3. matrox vs voodoo
    By nosuchluck in forum MURC Gaming
    Last Post: 28th January 2000, 15:28
  4. Voodoo 4 in October
    By maxie in forum Matrox Hardware
    Last Post: 29th July 1999, 08:27
  5. Voodoo 2000
    By Andrew D in forum Matrox Hardware
    Last Post: 30th June 1999, 13:00
