Crimson Skies issues with g400
  • Crimson Skies issues with g400
    Hey all, just wondering if anyone has the same problem as me with crimson skies, I looked in the readme and it said that g400 wasnt supported?? what is up with that?
    Is there a patch or anything out there? it looks horrible in software and runs too slow....
    p3-450 128 mb sb live, 16mb g400 win2k
    That's mad, the demo works perfectly well with a G400. I can't see why they have to move the goal-posts with the final version to make it not work at all with a G400. Maybe an earlier/later driver version might help, or running it with the minimum texture detail possible?
      I have Crimson Skies running seemingly fine with my G400 Max.
      Hope this helps you
