Is a G400 32 meg AGP card (not the max) a good card for my K6-2 450, 128 megs sdram?
  • Is a G400 32 meg AGP card (not the max) a good card for my K6-2 450, 128 megs sdram?
    Also has matrox fixed its previous problems in performance in opengl? Im upgrading from a Viper 550 AGP 16 meg
    ***TRUST IN YOUR TECHNOLUST***
    <A HREF="http://jediphoenix.iscool.net/
    " TARGET=_blank>http://jediphoenix.iscool.net/
    </A>
    The Matrox is very CPU intensive. I love mine, and would recomend it if you had a faster CPU, but I don't think its the best solution for you. My K6-2 400 looked great with it, but was very slow. Now, with a K7-500 it cranks out the frame rates.
    If you can't upgrade the CPU/MoBo for a while you might want to think about one of the T&L boards out there. If you're gonna upgrade the system though, get a G400. Picture quality and DualHead (Awesome!) are the best there is.
      And Socket 7 AGP is a PITA with any AGP card ,Voodoo3 excluded, but then they're not really AGP cards anyway
      DS
      Games Box
      Windows 2000Pro, ASUS A7Pro, Duron 750@950, 192MB Micron PC133, OEM Radeon DDR, 15gb Quantum Fireball+ LM, Fujitsu 5.25gb, Pioneer 32x slot load CDROM, SB Live! Value, LinkSys LNE100, Altec Lansing ACS45.2, Samsung Syncmaster 955DF, Sycom 300va UPS
      Video Box
      Windows 2000Pro, PIII700 on ASUS CUBX, 256mb Micron PC133, Vanilla G400/32 (PD5.14), Hauppage WinTV-DBX, LinkSys LNE100, 8.4gb Maxtor HD, 40gb 7200 Western Digital, Diamond Fireport 40 SCSI, Pioneer 32x SCSI Slot load CDROM, Pioneer 10x Slot load DVD, Yamaha 4416s burner, MX300, Panasonic Panasync S70
      Feline Tech Support
      Jinx the Grey Thundercat, Mischa (Shilsner?)(still MIA)
      ...currently working on the world's first C64 based parallel computing project
