Driver problem
  • Driver problem
    Hi, just installed the demo of driver, and i get the following message when running the configuration program:
    Fatal Error - No Compatible 3D Devices Detected
    i've tried switching desktop to 640x480 16 bit (advice from driver faq) and that didn't work.
    I have 5.30 with dx7, win98, g400max
    Dan.
    When you open Windows,
    bugs get in!
    "Linux is like a Wigwam.. No Windows, no Gates, and Apache inside."
    I never have played that game, but I get a similar message when detecting hardware in NFS4. But the game still runs. Bit slow but it's a "Glide At Heart" game so...
    P.S. Maybe I can coin a phrase here?
    AssuP2B ,300a at 337, 128megs PC100, G40032megSH, Yamaha PCI sound,2 small HD's, 42X Sony CDrom and 98SE w/shutdown patch, PD 5.25 w/beta ICD
    AMD XP2100+, 512megs DDR333, ATI Radeon 8500, some other stuff.
      works fine for me... you should try removing and reinstalling your drivers...
      Z
        also make sure you got the newest non beta demo of driver. the beta leaked demo was 3dfx only
          Found problem. I had it too. Change your display option to True Color (32 bit). This will probably work for other games that have this problem. Have fun Driving.
          "I will stop...the first wave"
